04-14-2024 09:33 PM
Hello. I just switched to Public Mobile and everything works expect my SMS in or out. Can you please help. I have done resets of network, cellular, messenger etc. and still does not work.
04-15-2024 12:53 AM
I think you can first wait 3 business days ,sometimes public mobile need time to deal with your problem if still not working you can contact agent for help
04-14-2024 09:41 PM
Thank you very much, yes it is just SMS. I appreciate your help.
04-14-2024 09:35 PM
HI @Jeff_519
was it just sms issue? can you get inbound calls?
if SMS, probably a problem with activation. Please ask PM agent to refresh your account.
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
04-14-2024 09:34 PM - edited 04-14-2024 09:35 PM
Public Mobile is dealing with issues when it comes to SMS on Android and iMessages and FaceTime and such. There is no ETA of when it will be resolved. Here is their announcement.
We are aware that some of you are currently unable to successfully use iMessage and or FaceTime features, and we understand how frustrating this can be. Our teams are working diligently to find the cause.
In the meantime, please try troubleshoot steps:
Tap Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
We apologize for any inconvenience this may have caused and will continue to keep you updated.
Thank you,
Keep an eye on this thread as they SHOULD update it when things are fixed.
You are more than welcome to create a ticket but may take up to 72 hours to respond.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
