12-04-2025 08:40 PM
My phone was working fine, then yesterday it just stopped working. Tried turning off phone and taking out SIM and then rebooting. I've only had it for a few months. Plus, my brother referred me and he's not getting a referral credit. Very frustrated with PM.
12-05-2025 01:36 PM
I checked the blacklist. It's not there. Near Vancouver, no network issues that I can see.
12-05-2025 11:49 AM
hi @Nyah27
did you check the blacklist? please check just in case
and which city you are at? any local network problem like this?
12-05-2025 11:47 AM
It's always been handed down, so not blacklisted. I'll try the network reboot and then maybe take it to repair shop. Thanks.
12-05-2025 10:13 AM
@Nyah27 wrote:The SIM worked in dad's phone.
If the SIM card worked in your dad's phone, that means there is an issue with your phone. Maybe try a network reset of your phone (note: this will erase any saved Wifi passwords).
By chance, did you purchase your phone secondhand? Might it be blacklisted for any reason?
Check your IME of the phone on this website:
12-04-2025 10:15 PM
12-04-2025 09:44 PM
hi @Nyah27
it won't mess up, just to test if it is the account/sim card
12-04-2025 09:37 PM
Account status seems normal. If I put it in another phone, will that mess up that phone?
12-04-2025 09:19 PM
hi @Nyah27
did you try using the sim card on another phone?
did you login My Account to confirm your account status?
12-04-2025 09:08 PM
r send a private message To CS_Agent
