SIM size iPhone 6s - 12
judydowney
My sim card from my iPhone 6s doesn’t fit new iPhone 12
10 REPLIES 10
@judydowney wrote:
Thank you so much for your help!!  It worked!!
What worked? Was it upside down?
judydowney
@hTideGnow
Indeed, makes them feel special for having the first one of something new.  🤣🤣🤣
@Luddite wrote:
 Gold side down in 6s; up in the 12. Weird, I agree.
Apple needs to make something "new" for each new generation  so people will buy  🙂
With that notch off the corner of the card, there's only one way it can fit. Unless the notch isn't in the tray I suppose. Which it being Apple and their splendiferous design and marketing one would think it would be obvious /s
Luddite
@judydowney  Gold side down in 6s; up in the 12. Weird, I agree.
Triguy
They are the same size nano SIM.  Make sure any label is facing you.
@judydowney
this is the way to put it
iPhone1212SimiPhone1212Sim
If still not work,  take a pictures like the above and post it here
judydowney
The whole thing that holds card doesn’t fit
cavemantoronto
They both use the same size. Check it's in the right direction.
