12-05-2020 10:34 AM - edited 01-05-2022 05:39 PM
Hi, I purchased a Public Mobile SIM and did the prepaid thing back in October this year. I went to a kiosk and the employee did the registration etc for me. I gave the employee a referral code from my friend and since October my friend has not received their reward - and if I'm supposed to get a reward for it I have also not received a reward...
12-05-2020 03:08 PM
I think so you might be miss some of letter of your referral code and you can also talk with customer service they might be solve your problem.
12-05-2020 12:48 PM
type "missing rewards"
(use the chat bubble options, then click "click here to submit a ticket!)
*login using your community account
make sure to check your inbox(top right corner envelope icon) periodically, for a response
12-05-2020 12:39 PM
I did a friend referral last month and it took a while to show up on my account. I would try getting ahold of customer service and see if they can apply the discount since it's been so long.
12-05-2020 10:37 AM - edited 12-05-2020 10:38 AM
Hi @horses_rule
Is the reward not showing on either of your self-serve accounts? You'd see a $10 credit and your friend would see a $1 refer-a-friend credit.
If not, contact moderator to advise.
To contact a moderator, there are 2 methods:
12-05-2020 10:36 AM
Contact moderators with your friends referral code https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
