SIM CHANGE
luxiline
So I lost my SIM card and got a new one. I went on my account and followed all the steps to “Change SIM” all was good! I put the SIM back into my same phone I was using with the previous SIM and it’s saying no SIM. This tells me that obviously the system on public mobile didn’t correctly activate the SIM through their system. How can this be fixed?
1 ACCEPTED SOLUTION
Accepted Solutions
darlicious
@luxiline
The new sim card could be a slightly different size. Check that there is no dirt or debris in the sim card slot/tray or on the sim card. Make sure it sits snugly in the tray. You may need a little paper shim or well placed piece of tape to secure it so the sim card makes a good contact with the phone.
Edit:
@benfatto  Sim cards cannot be swapped out in lost/stolen mode.
18 REPLIES 18
MrSpock
@luxiline did you reboot your phone? what does it say in your account now is it the new number?
@luxiline  Sim change should be pretty instant
Try one more reboot.
Or you can log back into Change SIM page and you can compare if the last 4 digits showing there is the new sim
If still not working, open ticket with PM Support
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
luxiline
Number is the same. All I changed was the SIM. I have rebooted multiple times and it’s still saying NO SIM. My account shows everything is fine and the new SIM change was successful. My phone says otherwise…
CountyDownIeUk
@luxiline
What @softech  is saying.....when you do a SIM change the last digits of your SIM shows at the start of the process.  So go back and take a look...the digits showing....are they the new card or the old one?
@luxiline   Yes, if you go back to the SIM change page now, you should see the last 4 digits showing there is the same as the last 4 digits of your new SIM.  If they are different, then maybe the earlier request didn't go through
@luxiline   and I am looking at the error again, it said NO SIM.  Usually No sim is an error showing the device not detecting the sim card or a faulty sim card
Try to reseat the sim card (power down, take sim out and put it back and power it back on)
and if you have another phone, try on the other phone as well.  If it is same NO SIM error, very likely a faulty sim
luxiline
Everything is as it should be. I’ve checked multiple times and it is the new SIM digits…
benfatto
@luxiline  If you activated Suspend service be sure to click Resume service. Just changing the SIM will not reactivate service.
@luxiline   Check my other post about reseating the sim card.  Try it
and try to put it on another phone
If it still fails after reseating and on another phone, open a ticket with PM and they can arrange for reimbursement of another new sim card.  You just need to go out and buy a new one
