03-02-2024 02:43 PM
Has anyone from Canada purchased the add on for US (15 day $30) talk,text,3 gb data does it work on the cruise ship ?
Thanks
03-02-2024 09:42 PM
Thanks
03-02-2024 02:51 PM
Why wouldn't you just switch to the $34 5G 50 GB CAN/USA plan and then have an entire month of calling and not have to spend an additional $30 + whatever your current plan is?
I imagine that as long as you are within US borders, your plan is fine. Once you enter foreign waters (if you are) then your plan would become useless without a different package as only Canada and the US applies.
03-02-2024 02:51 PM
Afternoon @2010Bill
Public Mobile will only work in Canada and the United States. Purchasing a US add on will have zero value to you. Plus, from what my buddy told me, you can purchase data allotments on the cruise. And if you REALLY wanted to, you can download a VOIP like TextNow on your phone, use the WiFi on the cruise and other areas of port to make and take calls from back home.
03-02-2024 02:48 PM
hi @2010Bill not on cruise ship
Will only work if you are at port in US
