07-16-2024 06:54 AM
Going to a cruise in Caribbean, St Croix, St Thomas, St Lucia and st Kitts, is there a roaming package that I can buy as add-on?
07-16-2024 09:32 AM
St Croix and St Thomas are both unincorporated territory of US.
Below are some important things you should know about U.S. Roaming add-ons:
07-16-2024 08:44 AM
You can also use Fongo for free calling and texting on wifi.
07-16-2024 08:29 AM
No you can't. But if you have wifi where your going you can use apps like WhatsApp and textnow for free or you can pick up a local sim and provider for the time your there.
07-16-2024 06:56 AM
@Mateng Sorry PM only works in Canada and the U.S. with roaming . You be best to get local pre paid SIM card in your destination
