07-16-2024
05:20 AM
07-16-2024
05:13 PM
computergeek541
I ordered my sim on the 5 th of july I haven’t received it yet how long does it usually take to get the sim delivered
07-16-2024 09:27 AM
it has been just 10 days, but it should come this week. If you are worry, ask PM and confirm
07-16-2024 09:24 AM
Mine took about two weeks. Guess it depends on your location.
07-16-2024 08:37 AM
If you need it soon you can pick one up at telus and kudo store for $10 or order one off Amazon for $5
07-16-2024 08:04 AM
Maybe you should order another one because it normally don't take that little
07-16-2024 05:58 AM
It could take 3-4 weeks.
07-16-2024 05:32 AM
@Jetlin Usually with in 10 business days but can take up to 3 weeks to arrive .but I think you will be seeing it very soon . But after 10 bussinesss days you can message support for an update on when it shipped and when you can expect it
send direct private message to support .
