01-05-2022
05:03 PM
01-06-2022
10:01 AM
Dunkman
Hello
Hopefully I did this correctly. I did the mistake of cancelling my account before transferring the number. I did check and no one has taken the number.
is there a way anyway to get my number back?
we had that number for 30+ years.
01-05-2022 04:48 PM
@Anonymous
Lol I guess I only answered the OP in two threads out of?
01-05-2022 04:43 PM
@darlicious : The customer has been into several threads. One of them they declared that the Rogers account is closed.
01-05-2022 04:42 PM
The OP has not confirmed the time frame or if they replied YES to the PAT.
Check your private messages. Call the telus porting department number first to confirm the status of your port before using the change number feature. If it can be ported thru the telus porting department then that is the first step you should take.
01-05-2022 04:36 PM
@Laurettelajoie : That seems to be the key right there. Your Rogers account is closed. Providers don't let numbers go from a closed account.
01-05-2022 04:34 PM - edited 01-05-2022 04:55 PM
@Laurettelajoie wrote:Rogers has my number as well and it's not being released. Why? I dont know. No one else has it
So, you confirmed that Rogers still have the phone number? It either you didn't reply the text within 90 mins or for some reason Rogers never release the number. You can try to call Rogers and ask but I doubt they will take any responsibility. (but at least they are nice and willing to allow the porting on the phone without you buy a new Rogers SIM and reply the SMS)
You will have to use Change Number as I suggested above and re-request the Porting.
Then call Rogers on that 1-800 number you mentioned and make sure they approve the porting without the SMS authorization
UPDATE: oops.. this is a different person from OP.. @Laurettelajoie when did you port your number? you can make outgoing calls?
01-05-2022 04:33 PM
Did you reply YES to the PAT(porting authorization text) within 90 minutes of receiving it on your Rogers sim card/service?
01-05-2022 04:28 PM
Can I have the phone number? I'm having the same issue with Rogers now as well.
01-05-2022 04:26 PM
01-05-2022 04:24 PM
For me Rogers is refusing as the account is closed. They have the number, no one else does, they just don't want to release it. I don't understand why
