01-12-2024 01:07 PM - last edited on 01-12-2024 01:32 PM by computergeek541
Hello, I have not received the new confirmation text and it has been over 90minutes. I tried the chat function with no luck and the submit ticket has been broken all day. Is there another way to reach out to support?
01-12-2024 01:38 PM
No sorry for the confusion I had my Rogers account deactivate early and then got it back online however I now need a new text message confirmation from Public
01-12-2024 01:28 PM
hi @Dauntliciti so you had incoming calls before and just stopped ? If you had it before, you can submit support ticket . But if it never works, quicker to call porting team.
I think you providboth ways already, let us know
01-12-2024 01:18 PM
@Dauntliciti Ok then in that case here’s direct link for support to help instead
send a private message To CS_Agents
01-12-2024 01:16 PM
It is now however I had some issues with the service this morning which could have caused it so if we could have it resubmitted I would appreciate it
01-12-2024 01:09 PM
@Dauntliciti I’ll send you the porting team number private message and they can re trigger the port request for you
01-12-2024 01:08 PM
your Rogers account is still active and can receive text without problem??
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
