Roaming
sab2535
Hello
I need international Roaming for two days, how can I do that. Please reply urgently
7 REPLIES 7
@sab2535 wrote:
Hi
I just need to receive an sms message to activate my WhatsApp while I am in overseas. Is it possible
Sorry, but using your Pubilc Mobile service, you won't be able to receive any text messages while you're anywhere but Canada or US.
sab2535
Hi
hairbag1
To buy the 10 Day US Roaming add-on...log in to your PM account (using incognito mode),  On left side of page, click Plan & Add-ons ...look to the right and find Shop Add-ons. Once you click that, you'll be taken direct to the US Roaming Add-ons. Make you selection and pay using your on-file credit card / Visa debit card.
Alternative is to dial 611 and follow the prompts..again paying with your on file cc or debit card. You'll need to know your PM pin number with this method.
Nobody has much faith that the talk portion of the add-on will work consistently, while in US. Best bet is, once in US, select T-Mobile as preferred network. Make sure to enable roaming in phone settings too.
Good luck...let us know what your experience with the add-on was.
hycm53
@sab2535 PM doesn't have international add on, PM only has US talk, text, data add on for 10 days.
ZuckMark
There is no International Roaming in PM! Get away!
ShawnC13
if you are in the US you can purchase a roaming add-on.  If you are somewhere else then you will need some other provider besides PM
Hi @sab2535 PM only has roaming service in US and no where else.  So, if you are not in US, you will  need local data sim
