08-06-2025 04:36 AM
I'm subscribing public mobile. Unfortunately i didn't know that the public mobile doesn't provide roaming service except usa.
Now I'm in South Korea now. I have to recieve the message from service canada for log in. What should i do?
08-06-2025 10:03 AM
sorry @Serena_Jung
you can't. Textnow will give you another 10 digits phone number and you need to give this another number to friends for calls and text
and you cannot use the VoIP number to receive any 2FA codes
08-06-2025 09:58 AM
I know. I tried to find the option for sending the cond to email, but i couldn't find it. Can textnow recieve the text to my current using phone number?
08-06-2025 06:17 AM
@Serena_Jung You can Download VoIP app TextNow. It works like a phone but it is an App.
While TextNow can receive text, but 2FA type of text is NOT free on TextNow. Otherwise, maybe there’s an option to send the code to email? Your phone should still work using local wifi to connect to internet.
