Roaming
ananyachopra06
I need to check if my plan covers Canada-wide-roaming, and I hope there's no additional cost. Would I be able to make and receive regular calls within Canada?
JL9
I am assuming you are not on one of the old provincial plans that were onky around for a short time, so you are golden
LeePublic
Yes, you can use PM services no matter where you are in Canada within Telus/Bell networks as PM is owned by Telus and they have agreements with Bell to use their network.
darlicious
@ananyachopra06
As long as you are in Canada their are no restrictions to the ability for you use your services as per your plan and any add ons you may have. You can recieve texts and voice calls from just about anywhere on planet earth and you can text anyone back and call anywhere in Canada to anyone within Canada unless as mentioned you have an older provincial calling plan. Data can be used anywhere in Canada as well. You have no worries in regards to extra cost as there are no overages, extra billing or fees with public mobile.
Hi @ananyachopra06 if you have Canada wide calling,  then yes, you can call and receive call anywhere in Canada.   And your mobile data is Canada wide as well
dust2dust
All services work while in Canada and connected to the network. If you have a provincial-only plan then you can still call within the province you're in. No such thing as roaming here.
hairbag1
All current plans include Canada wide calling from anywhere in Canada.
