Roaming purchased not working
DebbyDave
Help! My husband is traveling in the states. I purchased roaming for him, and he could dial out at first, but the sound did not work on the phone call, then disconnected.
What can be done?
Thanks,
Debby
Work order please?
NDesai
@DebbyDave Make sure he turned on roaming services on his phone. Normally, phones should automatically pick up local US signal, but sometimes you have to manually choose US roaming service network such T-Mobile or AT&T.
If he has option for voLTE on his phone turn it on ,and that could help also
DebbyDave
Thanks, it's different then the typical network problem. We had that when traveling thru different states, you just get no signal then. This is signal, but not enough to talk. Thanks though.
@DebbyDave  Tell him to make sure he’s connected to T mobile and reboot  the phone , US roaming can be hit or miss . If it just doesn’t work for him . Contact support for a refund / credit
Message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
