02-29-2024 12:22 PM
02-29-2024 12:38 PM
@sarahjparkk At the end of 90 days you will have 3x the rewards so $24 towards your next renewal
02-29-2024 12:30 PM
On the first payment of 90 days, you will get 30 days rewards since the rewards is based on the previous cycle. Afterwards, you should get friend, community and loyalty rewards every 30 days automatically. Autopay of $6 will be credited every 90 days.
02-29-2024 12:29 PM
Rewards are tied up with your account, not plan so you can change to any plant you want and rewards stay the same (unless YOU change to points).
