03-26-2025
06:17 PM
03-27-2025
08:16 AM
computergeek541
As title says, could customer who ports out number to other provider and then comes back to PM after, lets say a year or so, reuse email to open a new PM account?
03-27-2025 12:31 PM
03-27-2025 11:15 AM
Easiest way would be to use alias (if it is gmail account) as mail will go to the same mailbox but email will be 'different'.
03-26-2025 07:29 PM
hi @Meow
you can. But you might need to asl PM support agent to manually "release" your email so you can reuse it.
03-26-2025 06:25 PM
@Meow wrote:As title says, could customer who ports out number to other provider and then comes back to PM after, lets say a year or so, reuse email to open a new PM account?
Hi @Meow
I would say 100% yes. Once your account is closed from porting your number, all data is supposed to be erased. Therefore you should be able to reuse the same email address a year later without issues.
