Resume data service
rh66
plan renewed, still no data. Tried restarting 5 times, tried everything.
got the automated message 2 hours after plan renewed?
any suggestions?
27 REPLIES 27
Oana_S
Customer Support Agent
Hey @rh66,
Happy to help,will contact you in PM.
Have a great day:)
rh66
over 24hrs no response no fix still not working
rh66
yup
stonechucker
@rh66, I'm wondering if this is a return of the bug discovered when the 3G speed plans first came out.  There was an issue on renewal, that did not renew the data portion.
Please contact the Moderator_Team about this, if you haven't already.
@Alan_K, a reoccurrence of this possibility?
rh66
yup
@rh66 wrote:
@Alan_K  be appreciated to look into those who reported first
So you saw his reply to a couple other people. Did you send him your particulars as he asked of them?
rh66
rh66
being ignored Smiley Mad
@hairbag1 wrote:
Not suggesting anything other than probing the moderator for a fix to an issue that's affecting more than 1 customer recently....namely loss of data after renewal.
Ok. I didn't know if it was. So yes for both of these folks (so far)...moderator.
rh66
for me its just data problem
@hairbag1 wrote:
@codyb wrote:
having same issue on 8 gig plan renewel from last night.
You can send a message to the moderators and they'll give you instruction on a fix for this problem....Click this to message them
Please allow up to 48 hours for them to respond....usually a lot less.
Keep an eye on Annoiuncements for latest information.
Good luck.
 @hairbag1 Are you suggesting this is a continuation of the same problem? Is it a roving problem of no texts or no calls and now maybe even no data?
Good luck.
codyb
@rh66 wrote:
this is what is looks like when your data runs out for the month
and what it also looks like when you renew your plan and the data doesnt renew
Ok. I'd more interested in your overview page though.
rh66
rh66
This is just a regular monthly plan that is supposed to reset... this screen is still blank so i dont think its a phone issue.
Data & Add-On Usage
Usage for Phone Number 403-xxx-xxxx
Your Data & Add-On limit will show the total min./MB available on your account at the time of your last Add-On purchase.
U.S. Roaming Add-Ons expire after 10 days. Any unused data expires at the end of the U.S. Roaming Add-On. Add-Ons that are not U.S. Roaming related do not have expiry dates. Any remaining data or minutes in your Add-On will continue to roll over until they are used up. In-plan data expires at the end of your renewal cycle. It does not roll over to your next 30 or 90-day cycle.
@rh66 wrote:
no the data screen is blank as it was when ran out of data
Hmm
Could you maybe post a screen snip of your overview page. Blank out personal info of course.
duffer900
any suggestions?
If this was mentioned, ignore this.
You mentioned you were renewing. Was this just your standard renewal? Or did you renew after being gone for a while?
Did you happend to change devices?
If so,  maybe the APN settings need a massage...
android  https://apn-canada.gishan.net/en/apn/public-mobile/android
iPhone  https://apn-canada.gishan.net/en/apn/public-mobile/ios
If not, nothng to see here, and best of luck!
@rh66 wrote:
seriously... who has time for this experiment. obviously this is a known issue?
@rh66  Make sure that your APN setting is PM and not Telus. For some uknown reason it likes to switch back to Telus on some phone models.
rh66
@rh66 wrote:
trying now... love being a beta tester paying for service.
It's a clunky, buggy, rattly old system here...but it works just fine for the vast majority of customers...until it doesn't. Here you are. 🙂
The "trick" may not even work. We'll see.
I wonder if your phone has a data quantity blocker itself. Or if you look at the overview page does it show your data.
rh66
any suggestions?
What automated message 2 hours after?
You could wait however long for the moderators to figure it out or you could *try* ideas suggested by fellow customers. Ideas that have been known to work for many problems. Take your pick.
rh66
ZfromVanC
One last trick you can try is reporting your phone lost/stolen through your account. This will reprovision your plan and may kick start the system into turning your service back on.
1. Login to your self-serve account.
2. Report your phone lost/stolen using 'Plan and Add-Ons' --> 'Lost/Stolen Phone'
3. Log off
4. Wait 5 minutes and login again
5. Report your phone found.
6. Re-start you phone to enable all features of your plan again.
If that does not work you should contact a Moderator:
Heads up, depending on how busy they are, sometimes it can take up to 48 hours to hear back from them. To speed up the process, give them your name, phone number, account number, etc. when you send in your message.
Pizzaeh
any suggestions?
Try the lost/stolen trick:
Once you log into your account...
Click the 'Plans and Add-ons' tab.
Click 'Lost/Stolen Phone' tab.
Click 'Suspend Service' button.
Log out of your account and wait several minutes.
Log back into your account and report that your phone has been found.
