Going to Poland
a week ago
- last edited
a week ago
computergeek541
I am going to Poland for a couple weeks and wonder is there anything I can do for data or something to not pay big prices for service while there
edited by computergeek541: changed category label (unrelated to "community" discussion)
Service
a week ago
if you'll have wifi whilst in Poland, consider downloading the free TextNow app to your cell. You be given opportunity to select a free Cdn number so you can rec calls and texts (using wifi). You'll be able to call home and text for free (using wifi). I've used TextNow while away from Canada and it works fine as long as you have wifi or you can also use data that you buy locally
a week ago
@Tk12 Public Mobile does not have any service outside of Canada (and the US and Mexico with roaming plans or add ons) so you will need to look at a local sim/esim or use a voip app on wifi.
