Request refund due phone can't activate
Flyingtiger
I've paid 26.88 plus tax for 24 promo esim plan ,after all done got a fail to download due phone not compatible message & aak me to contact CSA for a refund
9 REPLIES 9
Flyingtiger
Do u know if a buy $24 plan & sim card to be picked up per their shop list is ok...1 of them is the telus shop in crystal mall ...qqq
Flyingtiger
Thk u...hv just try & waiting for result
@Flyingtiger wrote:
U hv their address....qq
HI @Flyingtiger
please submit a ticket with CS Agent here:
Flyingtiger
Flyingtiger
I've try no joy need refund
hi @Flyingtiger
just message them again.
Flyingtiger
Can't get CSA to answer
Surelydroid
I had the same issue last night. Do you have an esim already installed? If so delete it. Try again, if it still doesn't work send a Private Message to CS_Agent. They fixed it up in 5 mins. If you have no esim in phone order a physical sim off Amazon.
@Flyingtiger
if you really cannot activate the service, you can likley get a refund.  Please private message agent instead:
However, I believe you just couple steps away from successful activation. Try these steps:
Did you get to the eSIM installation step?   Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
