3 hours ago
I cannot active my account in Public mobile. Can I get the refund of my subscription?
3 hours ago
hi @ddfdfd
if the account was not fully setup and you want to opt out, PM support will provide full refund. But if it is just technical problem with setup , check with them and maybe they can sort it out, you can submit ticket by direct message:
3 hours ago
Public Mobile does not usually offer refunds. What exactly happens you try activating your subscription? Public Mobile app is needed.
3 hours ago
PM doesnt normally offer refunds, but if you havent even activated your account i would try messaging them and asking for a refund, you can message a customer support agent here:
3 hours ago
yes, you can. just need to ask PM. message them using this link:
