02-14-2021 08:58 PM - edited 01-05-2022 05:17 PM
My charging port on my Moto G7 Play is on its way out so I ordered a new board from Aliexpress (only place to find it without paying crazy shipping costs to Canada). My old board works fine but the pins are messed up so it could fail to charge basically at any time.
I purchased this board but when I assemble everything it says no sim found in the Android quick menu and says sim disabled in the sim settings.
I got the US version that matches the shape of my existing board. Both antenna cables connect fine. Aside from some really small lettering on the boards I wouldn't know they were any different. Other boards just have connection for one antenna and are a different shape so they wouldn't fit.
Anyone know of any trickery I need to do to get this to work? or is it just a faulty part?
06-27-2022 09:33 PM
@raindog317 curious, you just replaced the charging board and not the whole motherboard of the phone?
06-27-2022 09:31 PM
I registered here JUST to reply to this. You are not crazy! This literally just happened to me. I have 3 kids, all with moto G7 Power phones. I have replaced 2 charge ports about a year ago no sweat. The final phone finally had charging issues that no cleaning would solve, so I went to rebuy the other boards I got before and they were out. So I just clicked the one from amazon that had next day delivery and called it done.
I swapped the board on the phone and the charger worked GREAT! Until I realized that my sons phone had no signal?? It said the SIM wasn't there. There were no IMEI codes or anything! I removed and re-added the sim. I tried a sim from a siblings phone, I tried a different tray, I tried without the back on in case it was putting odd pressure somewhere after removal and adding back. NONE of it worked.
In desperation I swapped the old board back in. The SIM was IMMEDITEDLY detected and worked as if it had never stopped.
It is absolutely something with the charge board. Even though it is nooowhere near where the sim electronics are on this phone model.
Crazy stuff.
02-16-2021 06:17 AM
@dlambro They do carry a board for a Moto G7 Play variant but they either have the wrong thumbnail or its the incorrect part for my variant. I purchased my phone direct from Motorola,ca. The part is really difficult to find.
02-16-2021 06:15 AM
@Nezgar The tray just takes a sim and a microsd. The sim does work with the original board so I don't think its an issue with the sim placement or tray.
02-16-2021 12:33 AM
You may be better off buying another board from a Canadian store, instead of going through ebay. Did you check out esource? I bought a charging port for my iPhone from them and it works great, delivery was fast too, only took 3 business days to get to my house. Shipping was $2.99. here is a link to their site, just in case you want to try another part for your phone: www.esourceparts.ca/parts/phone/motorola.html
02-15-2021 11:08 PM
@Tav Does your moto G7 play have 2 sims like this? I'm sure you're putting it in the right slot (SIM1 vs SIM2)... I setup a Huawei P30 for my wife a few months ago, and that phone uses an "NM Card" - which is basically a MicroSD card in a nanoSim size - and for a bit I couldn't figure out why her SIM card wasn't workin in her phone until I realized that I had the SIM in the NM slot....
02-14-2021 11:13 PM
I agree. If we ever get access to Fairphones we will all be much less dependant on the throwaway society we've become.
https://productioncommunity.publicmobile.ca/t5/The-Lounge/Fair-Trade-in-Canada/td-p/654863
02-14-2021 10:53 PM
Thats what I'm thinking. I've already started a claim for a refund.
I'd probably have better luck buying a busted G7 Play on eBay and grabbing the part from that.
02-14-2021 10:50 PM
Faulty part? It is from Aliexpress.
02-14-2021 10:45 PM
Did you reboot phone? Yes
Does work on wifi etc without sim? Yes
Does it work on wifi etc with the unrecognized sim? Yes
Do a full reset? I did a network reset but not a full phone reset
02-14-2021 10:12 PM
Do a full reset?
02-14-2021 09:54 PM
@LurganIeUk I didn't look at the instructions prior to just now. But yes. I have followed those instructions.
I know I'm doing it correctly because I've tried both boards multiple times and the old one always picks up the sim.
02-14-2021 09:51 PM
@will13am it's a completely different part that's nowhere near the sim. It does have two little antenna connectors that seem to connect correctly.
02-14-2021 09:46 PM
No SIM detection, and the loss of network connectivity, are issues that a lot of users have faced, particularly since the update to Android 4.4.2 Kitkat. This issue is also prevalent in the Dual SIM version of the phone, where one or both SIM slots don’t recognize the SIM card, or lose signal randomly, only to automatically turn back on.
Potential Solution –
02-14-2021 09:40 PM
Did you follow this?
https://www.ifixit.com/Guide/Motorola+Moto+G7+Play+Charging+Port+Replacement/131322
02-14-2021 09:37 PM
@Tav , does the SIM tray alignment on the new board match the old one? Would you be able to test out the SIM without assembling everything to make sure there is proper contact.
02-14-2021 09:17 PM
Putting the old part back in picks up the sim just fine.
02-14-2021 09:15 PM
@Tav wrote:My charging port on my Moto G7 Play is on its way out so I ordered a new board from Aliexpress (only place to find it without paying crazy shipping costs to Canada). My old board works fine but the pins are messed up so it could fail to charge basically at any time.
No SIM ususally means that a device can't physically see the SIM card. This could be a physical or electrical failure.
