10-13-2024 04:09 PM
Hi, I tried to add a 2nd phone number and choose a plan but you replaced my number instead. Now my phone line isn't working.
Thank you for getting back to me as soon as possible!
10-13-2024 05:09 PM
10-13-2024 04:43 PM
You can only have 1 account/1 registered email so that is the reason why when you port the second line over to the original account. It will be replaced with the new number.
You will need a CS_Agent straighten this issue for you.
10-13-2024 04:11 PM
hi @darlev67 PM had a simple system, one email for one account/phone line
if you want a 2nd line, you need to use another email to activate a new account
So, look like you got confused and lost your original number. PM support agent will likely able to help, please message them here
