12-01-2024 06:25 PM - last edited on 12-01-2024 06:49 PM by softech
For my number ###+###-#### . The phone I registered on line using a eSimcard is no longer available. My other phone that I will use is an Iphone 7 and doesn't take "e sim card". I need a physical SIM card with the same number ###+###-#### . Where to get it and how to attach the phome number it?
12-01-2024 06:30 PM - last edited on 12-01-2024 06:50 PM by softech
12-01-2024 06:28 PM - last edited on 12-01-2024 06:50 PM by softech
@luispub24 you can but for Telus / /koodo store or order from Amazon $4.99 there right now
Find SIM card Find a store near to you | Public Mobile
Amazon
once you have SIM card in hand log into your account profile page and sim swap the number like this
SIM SWAPPING profile tabs
This can be done on the app also , but if you cannot log into your account as support to sim swap it for you and you will keep your same number and plan , no worries
you can use the orange chat bubble bottom right of screen or send a private message To CS_Agent
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
hi @luispub24
this is just a forum and we are customers, for your own protect, remove the phone number . Go back to your post, click the down arrow on top right and Edit Message
Buy a PM physical sim card from Telus or Koodo or Mobile Klinik stores or via Amazon:
Telus or Koodo or Mobile Klinik store https://www.publicmobile.ca/en/on/pick-up-SIM
Amazon.ca https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/
Then message support agent and ask them to help to update your account with the new sim card:
