10-13-2024 05:25 PM
I'm in USA purchased add on for data usage in USA (I live in canada)
it seems to be working but is not showing the amount of data that I have used on my add on plan
10-13-2024 05:52 PM
Hey @Treen2
Go into your settings and make sure your data roaming is turned on. Then go to network settings and turn off automatic and choose T-Mobile as the provider and then reboot. This should resolve it. There is only a 1GB or 3GB addon so... try using the app as that's a bit more accurate sometimes.
10-13-2024 05:37 PM
hi @Treen2
maybe just browser cache, please use Incognito/private/secret mode on your browser to login My Account to confirm again
If same, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
