Puerto Rico (CAN-US-MEXICO plan)
gugu
Hi, I have the CAN-US-MEXICO plan that I subscribed to this Black Friday. Does this plan cover data usage when visiting Puerto Rico?
Were you chatting with a customer support agent through the private messaging?
It definitely should work @gugu
I presume you can receive calls from there (when in Canada).   Try calling back using the contact calling information from the incoming call from Puerto Rico. (as opposed to a saved contact)
If you can't make the call, try rebooting your device and try the call again.
Last resort, reach out to customer support to ensure you can - I can't see why you wouldn't be able to.   Please report back what they indicate.
  1. Use the ticketing system by clicking here , then Contact Us,  or,
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
gugu
Thank you for replying. That's what I thought as well but the customer care this morning said it's not covered and that I will need a data add-on. To me this doesn't make sense. Puerto Rico is part of US. I am also unable to call numbers in Puerto Rico from Canada whereas my plan does say unlimited minutes between these 3 countries., when I call a Puerto Rico number, it gives me error "You have already used up your minutes". Thoughts ?
HALIMACS
Yes, Puerto Rico is part of the US coverage, @gugu
PM has partnered with AT&T, Verizon, and T-Mobile to provide U.S. coverage which includes all 50 states (including Puerto Rico and the U.S Virgin Island...)
