Regarding: CAN-US-MEX 5G 75GB FOR $35/MO Plan
Sukhdev-Momi
PUBLIC.pngJust want to know details of this plan?
I am looking for Canada-US-Mexico roaming included with international minutes included.
1. Is this a  CAN-US-MEX 5G 75GB FOR $35/MO Roaming Plan with 1000 international minutes  or do I have to pay for Roaming to US and Mexico. Any data use limit or exclusions ?
2. Also on the website shows CAN-US-MEX 5G 50GB FOR $35/MO plan .
What is the difference between two plans?
Just copying the link from where I saw these two plans. One is subscribe Now.  Which one should I opt for ?
 https://www.publicmobile.ca/en/on/plans?network=5G
8 REPLIES 8
@Sukhdev-Momi
Personally I prefer the physical SIM. It is easier to just pop it out from one phone to another without any headaches.
I only use eSIM when I need service when I am out of North America and abroad.
check this video on how to transfer.  The later part on the video tells you how to transfer after you got a temp number
https://www.youtube.com/watch?v=M6joSfOewoA&list=PLLwfukjoQzbdvSkWRd1mHAXLfzvGpeoJ9&index=7
hi @Sukhdev-Momi
no same email on 2 lines.  For a 2nd line, you have to use a different email address to activate
physical or esim, it is a personal choice.  If you want to activate quicker, buy a physical sim from Telus or Koodo store
for port, just login My Account, go to Profile page and click Transfer phone number
Sukhdev-Momi
Thank you all, who replied to clear this CAN-US_MEX roaming plan ending Dec 31st.
I have to get two lines. Can I use the same email to get both lines ? How to proceed ?  Will order by the end of the day today.  Any suggestion on what I shall prefer Physical SIM or e-sim ? My new phones , which support e-sim is arriving 3rd of January.
After I activate my lines with temporary numbers/the local numbers Public mobile gives me. Then how to port/transfer my existing provider numbers to replace the temporary numbers?
Thanks you in advance again
ubonboy
It was my understanding that international 1,000 LD minutes I can call Thailand's phone number from Canada. Correct??
hi @Sukhdev-Momi
1. you use the plan in USA and Mexico like you are home.   So, you have full access to use voice/text/data and no limit
2. the 2 plans are pretty much the same but the $35/75GB is the boing day promo and supposed to be gone in couple days.  But get it now and you will locked into the plan (no worry about price increase)
HALIMACS
@Sukhdev-Momi
Calling, texting and data usage is available in the stated countries as if you were in Canada on a Canada-wide plan.  No, you don't need to pay for US or Mexico add-ons to get service.   The only date use limits are what's left in the cycle's 75GB allotment, after that the data will simply stop working.  The 1000 international minutes allows calling to countries outside of Canada, US, and Mexico.
Same coverage, except only 50 GB.
slusagm
@Sukhdev-Momi
no roaming charges, and no data limit, so you can use them all in US or Mexico
the $35-50GB and $35-75GB are basically same with different data amount.  But the  75GB is a special boxing deal, get that instead
