Refund
edilbertoBula
How do I get my outstanding balance to my account
10 REPLIES 10
edilbertoBula
It was my debit card
You didn't say. Was that from you depositing money there? Or is that built-up rewards?
edilbertoBula
Is that clear for you.
edilbertoBula
why you don’t know what I’m trying to do easy I need my money back!!! 300$ in my account back to my bank card which is registered to my payment method.
What stupid idea? Scroll down to the bottom and find Service Terms. Have a read. You'll find it says that there are no refunds here. Likely common with most prepaid providers.
But again, what are you trying to do?
edilbertoBula
Stupid idea, how you know, can you prove it?
JL9
No dice unfortunately, you used to be able to transfer the entire balance to another PM customer/account (so if you had a friend/family member still using it) you could do that as being a good friend or arrange some compensation, but unfortunately you haven't been able to do that for quite awhile now.
hairbag1
If you have a substantial balance, you probably best to keep your PM account until it's dwindled down.
Remember...your PM account needs to be active if/when you initiate a port away from PM.
@edilbertoBula
If you have outstanding balance before porting your number to another carrier. Unfortunately as @Dunkman indicated...PM is a prepaid plan so no refund.
Dunkman
@edilbertoBula
In general, since this is a prepaid service, there are no refunds with Public mobile. What is your specific situation?
