Billing
Cedric5
I registered for esim and cancel it the second day
When should i got the refund of 40.25$
hi @Cedric5
the person you quoted is not a support here
you need to submit a ticket using private message link on my earlier post
and as said, you might not get a refund as PM is a prepaid carrier and only provide refund if the system has trouble activating your account
Cedric5
I registered on esim and cancel it the second date
when shouls i get the refund
sorry @Cedric5 , PM is prepaid carrier and no refund if you cancel the next day, unless the service was never fully activated
if you like you can try to check with PM support and see if your situation qualifies
you can submit  ticket by direct message:
