06-26-2022 08:08 PM
since the sim card i purchased online was taking too long to come, i decided to go ahead and get one in a store (which i payed for.) how would i go about getting a refund for the one thats supposed to come in the mail?
06-27-2022 03:08 PM
@ZuckMark I don not think this is an appropriate comment.
You can click the down error on the top right of your post, click Edit Reply and remove them.
06-27-2022 09:40 AM
I agree this is definitely prob the best way to recoup the cost of the sim
06-27-2022 09:39 AM
Yeah definitely a pain, I wish more ppl would check on here before buying sim so they could avoid the huge delay.
Unfortunately a straight up refund may not be done but some of the other suggestions above could offset the cost
06-26-2022 09:31 PM - edited 06-26-2022 09:33 PM
Wait three weeks. If the sim card does not arrive within that time span since ordering contact customer support and explain the issue. Remit a copy of your sim card order from Public Mobile or the reciept of the newly purchased sim card (whichever is greater) and ask for a credit on your self serve account balance.
As per usual your acerbic comments are unnecessary. Obviously if you can afford a $15 cup of coffee you have no clue how to live on a tight budget nor empathy for those on a low or fixed income. If you don't have anything good to say....say nothing at all!
Edit to add:
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
06-26-2022 09:26 PM
HI @rusyaon you can try to discuss a resolution with PM CS Agent.
Since you are a PM customer already, you can open ticket using Chatbot:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
- start by typing : Contact CS Agent
- then Click "Contact Us"
- then Click "Other"
- finally Click "Click here to submit a ticket"
06-26-2022 09:19 PM
OMG, how hard are 10 bucks for you? Can I send you some pennies? I just spent $15 on a cup of coffee.
06-26-2022 08:18 PM
I wouldn't bother. Wait for it to arrive and use it for a referral some day. Earn points the fun and easy way.
Oh you think you might shop around for a cheaper service. Hey how about Public Mobile. Oh hey look at that I even have a sim right here. We can do this right now.
06-26-2022 08:14 PM
How long has it been? Generally, refunds aren't provided unless the SIM card never arrives as.they are sold on a final sale condition.
06-26-2022 08:13 PM - edited 06-26-2022 08:14 PM
@rusyaon Hi I don’t know if they will but you can open a ticket, to speak to a customer service agent Click here or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
