02-05-2022 04:40 PM
02-05-2022 05:52 PM
You don’t get $10…only your friend that you referred gets the $10.
You get $1 credit off your monthly bill.
Also you should have got a text from PM telling you “Cha-ching! You just added to your Refer A Friend Reward - way to go! Keep referring to earn more. View your Rewards on your account”.
02-05-2022 04:57 PM
@ilbb88 The person you refer gets the $10 credit added to their account within 72 hours. You will receive $1 or 1 pt. (depending on when you joined PM and what rewards program you are on) every 30 days your referral stays with Public Mobile.
@Yummy as this person is the referrer they will not get the $10 as you stated.
02-05-2022 04:49 PM - edited 02-05-2022 05:12 PM
$10 will be credited to your account within 3 days. Thank you @ShawnC13
Log in into your account and if you see similar to this, referral process has been properly completed
and you will receive $1 off on your next renewal.
02-05-2022 04:46 PM
Hi @ilbb88
Refer a Friend: $1/30 days for each friend you refer – plus, your friend receives a one-time credit of $10.within 72hr they will be apply,
for new Rewards 1 point every 30 days.
