02-28-2024 09:04 PM
I signed up 2 new customers with P B with my referral code , 2 moths ago yet I do not see any credits on my subscription for the referrals , is there any issues here?
thanks in advance.
02-28-2024 09:09 PM
Should be there. You get $1.00 for each. Should show under your rewards tab. They each get $10. Did you check with them?
If you can confirm not there, then send cs a message at the link below.
Click, type, send
02-28-2024 09:08 PM - edited 02-28-2024 09:13 PM
I would suggest you contact a CS_Agent to investigate if your referral code was used at all or entered the code correctly.
DM them at:
If the code was entered correctly, you should got a text indicating “Cha-ching! You just added to your Refer a Friend Reward-way to go! Keep referring to earn more. View your Reward account”
Also the 2 members should receive a $10 credit after 72 hours.
02-28-2024 09:06 PM
@John2348 you are on the new Public Rewards system?? if so, the points will be added to your My Rewards. Please check the transaction history of the Rewards portal
if confirm not therez message support for further investigation
