02-28-2024
08:42 PM
03-01-2024
03:42 AM
computergeek541
I have been trying for the last 2 days to get my Aunt's phone working. I was directed one day one to contact the CS_Agent. I did that, but haven't heard back. Does it take longer than 24 hours to hear from them?
02-28-2024 09:03 PM
Strange but I will DM you a Porting Department number.
02-28-2024 09:01 PM
Checking it often and the inbox is empty 😐
02-28-2024 08:56 PM
Check by clicking on the avatar top right then under Messages.
02-28-2024 08:51 PM
Thanks! It has been over 24 hrs now.... and I have logged out and back in to make sure the page refreshes and nothing so far.
02-28-2024 08:44 PM
@Serendipitydw1 Usually with in the hour sometimes longer . Just keep an eye on your in box for reply . Or you can use this link to the in box
