Refer a friend
2Darla
Signed up under refer a friend but didn’t enter their code. How do I enter it now? Also although I have been signed up for 3 days my account has not been activated?
2Darla
How do I add the code number for refer a friend
The code is should be entered during actvation.  There are no guarantees, but to ask a customer support agent, oepn a ticket through the chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
While you're discussing that with the customer support agent, the activation status can be discussed as well.
@2Darla
You will need to contact a CS_Agent and explain that it was an honest mistake that you missed entering the referral code.
CS_Agent private messaging:
DDM69
I’m guessing your activation wasn’t completed. Submit a ticket with a CS representative to have them look into your account.
