eSIM
06-27-2023 12:51 PM
06-27-2023 12:59 PM
Thank you! I thought that’s what I was doing but now see the difference with a private message.
06-27-2023 12:54 PM
Hi @JGEL19
you can contact customer service by submit ticket here
06-27-2023 12:53 PM
you can message support to open ticket here
did you get to the eSIM installation step Either the app will ask for your permission to do it for you automatically, or you will get a QR code to install yourself. If you missed the step, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step), try to reboot your phone once. i
If it still does not connect, click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after)
if it still does not work, please open ticket with PM support as advised above
