Esim
Jonathan_79
Does anyone know which kind of phones support esim??
2 REPLIES 2
Chalupa_Batman
As mentioned by @hairbag1 , there are a lot of phones out there that support eSIM. The real question is, will that phone be supported by Public Mobile. Once you figure out what phone you'd like to get, check here to see if its' compatible with PM.
To confirm if your phone will work with Public Mobile, please see this link. At the bottom of the page, you can insert your IMEI number and the system will advise you if it will work with Public Mobile.
https://www.publicmobile.ca/en/get-help/articles/volte
Use Public Mobile's VoLTE checker as a guide only, as results are not always 100% accurate.
hairbag1
@Jonathan_79
there's so many different cellphones....just use google to find out if a particular cell is esim supported. What phone are you considering ?
