Refer a friend link is not working on mobile website
kamini_chintan
When I go to my profile and click on refer a friend then another page (irrelevant) loads and it doesn’t show any option to refer a friend
1 ACCEPTED SOLUTION
Accepted Solutions
MrSpock
@kamini_chintan Hi your Referral number is on the main page of your self serve account it is not in your profile
@kamini_chintan It could be just a browser/cache issue
try with a different browser (Edge/Chrome/Firefox), or try Incognito mode, or try clear cache and reboot
Lastly, you can also try on a different device
MrSpock
@kamini_chintan   Initially I thought you meant you page not load.  Just give the code to your friend to enter during activate.  E-MyAcct_ReferCode.png
You might see a link there after the code.  Do not use the link, the link DOES NOT work .  It just open the activation page
When your friend activate, he/she will be asked to enter friend referral code on Step 4
@MrSpock
@kamini_chintan
Ah...yes it is in your My Account Overview. That link used to take you directly to the Activation process and pre fill the referral code. They removed it when the Activation process was changed, which made sense as the referral code was no longer on the first page. But some wizard guru made some more changes and put it back into the My Account login.  So.......it is there but redundant like a lot of other stuff.
darlicious
@CountyDownIeUk
I wouldn't say redundant....I log in to the bf's account to get his all the time. I don't even think about using his rewards account....but it's there too....
@darlicious wrote:
@CountyDownIeUk
As being a link it is redundant. As information only it maybe helpful vs logging in to My Rewards.
