Reducing rings before voicemail answers?
Luciphone
@Luciphone  That’s PM voicemail number when people call you and it keeps track with that number but won’t count against your mins used
Luciphone
Does this number go to voicemail or someone else? 16475804001
eddieO
@Luciphone, Dial this sequence: *61 *61475804001*11 *[then enter number of seconds to wait] # [SEND or CALL].
For the number of seconds to wait - choose from the following options:
For one ring, enter 5
For two rings, enter 10
For three rings enter 15
For four rings, enter 20
For five rings, enter 25
For six rings, enter 30 (this is the maximum number of rings/seconds).
Example: *61*16475804001*11*20#[SEND or CALL] - sets your phone to ring four times (20 seconds) before going to your voicemail.
HI @Luciphone
try this on the dialpad
*61*16475804001*11*20#, then click send
this will let it ring 20 seconds before going to voicemail
(you can change that *20# to *5# for 5 seconds, or change to *10# for 10 sec)
@Luciphone   here’s quick read on voicemail options
Voice mail options
Voicemail FAQ | Public Mobile
