05-14-2023 03:49 PM
How do you recover your sim pin and PUK code ? and unlock your sim pin
05-14-2023 04:07 PM
@Beastgaming4040 wrote:I need PM to unlock my SIM card on there end now please
@Beastgaming4040 - we are all customers like you here on the forum. Please see @computergeek541 post to create a ticket to contact Public Mobile customer support for help.
05-14-2023 04:02 PM
05-14-2023 03:59 PM
I’m saying that I set a pin on my sim pin and I forgot the pin n now I need PM to unlock my iPhone on there end now!
05-14-2023 03:56 PM
hi @Beastgaming4040 you just got a new phone? wonder why you got this suddenly
05-14-2023 03:53 PM
Yes I been with PM for a year now and I don’t know how to resolve the solution
05-14-2023 03:53 PM
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK." ,
call Samsung 1-800-726-7864, The only info you will need to provide for a master unlock was the IMEI and where the phone was purchased
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed" or on an iPhone's status bar showing "Locked SIM"
open a ticket with PM Support using this direct link: https://urlshortner.tiia.ai/Oyn1L6
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier unlock code. (PM would not be able to help with this)
05-14-2023 03:52 PM
hi @Beastgaming4040 is that a carrier lock? only yours old provider can help
but PM can help with sim card puk
05-14-2023 03:51 PM
@Beastgaming4040 wrote:How do you recover your sim pin and PUK code ? and unlock your sim pin
Unless you have mnanually changed it, your SIM card's PIN is 1234. However, that code is unusable if your phone is prompting you fro your SIM card's PUK. You would first need to get that from a Public Mobile customer support agent. Customer support agents are contacting by opening a ticket using the chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
