Cannot call a rogers network cell phone custumer
Sammy2011
The phone will call everything except to a rogers network cell phone.
hi @Sammy2011 just one Rogers number?  try reboot phone or add 1 to the number to dial
This appears to be an intercarrier routing issue.  Please open a ticket using the chatbot:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
@Sammy2011 - if you just ported over a number from another provider or activated with a number, this may be temporary.
Try restarting your phone or perform a reset of the network settings.
If issues persist, submit a ticket to CSA to see if they can help.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
@Sammy2011 this could be your problem but could also be your friend's.  did you just joined PM or your friend just ported the number?
