07-31-2024 10:55 AM
Hello, I just switched from Virgin mobile to Public mobile. I have been able to use data and send calls, but I am not receiving calls or messages, nor can i send messages. Please help.
07-31-2024 04:06 PM
I figured it out. It happens to be that I was in a cellular dead zone. When I received the text, it was already long past the 90 minutes. I just called the agent to restart the number porting(in a better zone). It's all working now. Thanks.
07-31-2024 11:05 AM - edited 07-31-2024 11:06 AM
@Not_Dan - Please check your Virgin SIM card to see if both are still active. If they are, please call this number I will send you in your Private Messages (Mailbox in the top right corner OR Under your profile picture in the top right corner)
Please check if your Virgin SIM has service
Also how about receiving SMS / Texts? Do they work?
07-31-2024 11:03 AM - edited 07-31-2024 11:03 AM
@Not_Dan it sounds like the number porting process has not completed. How long have you been waiting? If it's been more than a few hours you should contact the CS_agent to see if there is something they can do on their end.
You can open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
07-31-2024 10:59 AM
@Not_Dan first restart your phone. If it doesn't, sounds like an account setup error. You can use the chatbot or orange bubble to send a message to Public Mobile to fix.
