Tuesday
so I'm new to public mobile activated today. So far really awesome Network runs off of Telus. Very happy with my purchase but I have the $30 plan which is 20 gigs Canada and us. Does that mean that I can roam in the United States as well and use my device like I can in Canada?
yesterday
Thank you! 👍 Good to know.
yesterday
HI @Chris_
your A70 is a 4G/LTE phone. In fact, if you have a 5G plan, you can get close to the 5G speed even with a 4G LTE phone
but of course, S22 has better network and would work better
But for speed, even the top speed on 4G plan , 100Mbps , would be more than enough for most regular users
yesterday
Ah I see, yes... that's right, thanks. But getting a newer phone may also improve my data speed, especially a 5G phone... I'm assuming
yesterday
yesterday
I can't afford much, since we gotta pay up for the phones these days, and with PM even more so... What I may do is check out Mobil Klinik here to use that promo we have access to, for the S22. My budget to buy a phone would be like 250 max, preferably under 200
yesterday
@Chris_ wrote:So if I get one of the phones on the list, my connection/speed/clarity/quality experience on PM may noticeably be better?
VoLTE only affects voice. It makes no difference when it comes to data or text messaging services.
yesterday
HI @Chris_
it would be better. Afterall, A70 is a 4 or 5 years phone already
A35 is the entry level phone that has VoLTE as well (someone confirmed)
Or if you want to get a better one, the S23FE , S24 would be a nice one to get
yesterday
@Chris_ For voice yes even here at home in rural areas
yesterday
yesterday
Ah Phew 😂
yesterday
yesterday
Huh? I literally got it from Koodo. I think Telus used to sell it too.
yesterday
yesterday
Samsung A70
yesterday
HI @Chris_
but what phone do you have?
and yes, the VoIP app would be the workaround. Fongo and TextNow are both good VoLTE apps to use
yesterday
@Chris_ That would be wise if you want have the best roaming experience
yesterday
Thanks, I think I'm coming round to understanding 😉
yesterday
Samsung A70... Seems I'm gonna need to fork out some dough for one on the list when I travel down there
yesterday
@Chris_ Unfortunately it has to be in the PM list , for example Samsung s20 is 5G phone you use it on Telus you get 5G network but here with public mobile you only get 4G/LTE because PM die not support that phone with 5G . So like voLTE with PM it needs to be on its whitelist to use the feature
yesterday
HI @Chris_
for us with PM roaming in US, we must have one of the phone on the list to use VoLTE. Sorry,
yesterday
So for roaming in the States, it doesn't have to be one of those on the list? For in the States, could it be ANY VoLTE phone?
yesterday
@Chris_ Yes many more those are just the phones that public mobile supports
yesterday
So there are more phones than just the ones on this list?
yesterday
@Chris_ wrote:Wow, amazing... There must be more VoLTE phones on the market than listed in that PM list than, yeah? That's quite limited.... Seems weird to think all Americans have one of such a limited selection of phones...
Hi @Chris_
there are quiet many phones on the market with VoLTE
and iPhone is main stream in US
yesterday
yesterday
@Chris_ Most phones are voLTE capable just not all carriers support its use . This becomes issue when 3G is shut down like it mostly is in the U.S. and why its issue if your carrier doesn’t support your phone . Here in Canada we can still get away with 3G plan but it’s set to end soon in next couple years and 3G will be shut down here too forcing people onto 4G plans or start supporting more phones with voLtE
yesterday
HI @Chris_
Yes, for US customers for US carrier, they all need VoLTE phones
For us roaming in US, because Canada still has 3G voice, we are caught in between
yesterday
So do all customers in the US have VoLTE phones than? Is that the only way Americans can use voice?
yesterday
HI @Chris_
only voice might not work, both data and text will still work
for voice, you might still be able to use T-Mobile's 2G network if you don't have a VoLTE whitelisted phone. But the T-Mobile 2G network is shutting down soon, so you might not be able to connected
but workaround is that you can use VoIP app like TextNow to make and receive phone calls on the app using another 10 digits number
yesterday - last edited yesterday
@Chris_ Just voice calls will be issue text and data will still work fine
