01-22-2021 06:23 PM - edited 01-05-2022 04:58 PM
02-11-2021 01:44 PM
Being a 5G capable phone make sure you don't have 5G as your network type. Set it to start at 4G LTE or even 3G WCDMA UMTS HSPA.
02-11-2021 01:32 PM
@Mattnic wrote:I have tried all of these and I've tried my phone in at least 30 other devices and it works normal.
If it were locked you would think a network code box would appear when I insert another sim.
However it only says searching. I wonder if the phone my have network connection issues .
Yes: An android phone would defiinitely ask for an unlock code if the phone were still locked to T-Mobile. Even if the device was blocked out from unlocking incorrect codes being entered, you'd still be prompted for the master unlock code.
02-11-2021 01:23 PM
02-11-2021 03:48 AM
A couple of things to try.....
02-11-2021 01:32 AM
@Mattnic : Try power off phone with SIM in it then turn on again, maybe that will help.
02-11-2021 12:18 AM
You had posted 3 weeks ago in a different thread. Have you tried to reseat the sim in the phone. If the sim is loose, maybe shim up with a sliver of paper.
02-11-2021 12:03 AM
@Mattnic wrote:Hello,
I have a Samsung s20 T-Mobile unlocked
I can't connect to cellular. It just says searching.
This phone is compatible. Have you tried your SIM card in another device?
02-10-2021 11:59 PM - last edited on 02-11-2021 12:00 AM by computergeek541
Hello,
Model number sm-g981u
IMEI xxxxxxxxxxxxxxxxx
Please help thank you.
edited by computergeek541: IMEI removed as it can be used to port a number
01-23-2021 01:31 AM
@Mattnic wrote:Already did try it , it's not working. I replaced the charger port so I'm wondering if that did it. It was broken when I got it, but it's a sm-g981u
That certainly should work. Are you getting any messages from the phone when you put the SIM in? You did activate an account right?
01-23-2021 01:28 AM
01-22-2021 06:29 PM
@Mattnic wrote:Will Samsung s20 5g T-Mobile version unlocked work with public mobile ?
Yup, it should.
If you know anyone on Public Mobile, you could always try their SIM in it first to make sure all call/text functions work. Then, you'd be sure.
01-22-2021 06:29 PM
