04-02-2021 03:07 PM - edited 01-06-2022 02:26 AM
I don't even know my 4 digit code to make a payment using *611. Do you by chance know how I can do that?
04-02-2021 03:17 PM - edited 04-02-2021 03:18 PM
@EmmaPolania wrote:I don't even know my 4 digit code to make a payment using *611. Do you by chance know how I can do that?
@EmmaPolania If you cannot retrieve your Account PIN by @Dunkman 's method you can only obtain it or change it through the Moderators.
To contact the Public Mobile Moderator_Team, there are two ways to reach them:
1 - Faster Method - Click the bubble comment circle on the bottom right hand side of your screen, or use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower Method - Use this link to:
Private Message to Public Mobile Moderators (PM Customer Service Representatives)
FYI - your Account (4 digits) PIN is different from your Voicemail (4-15 digits) PIN.
Maybe try your voicemail PIN for your account PIN (incase it is the same, if it is 4 digits).
04-02-2021 03:17 PM
@EmmaPolania Are you able to login to your account? Once there make a manual payment for the amount owed, logout and reboot your phone.
If you cannot login, only option is to get a voucher and enter it via 611.
Voucher locations: https://www.publicmobile.ca/en/on/store-locator
Vouchers on-line: recharge.com , https://www.ding.com , https://canadiancellsupplies.com/
If you cannot reactivate, or just want a backup, checkout https://www.fongo.com/fongomobile/ and https://www.textnow.com/
To reset your 4 digit PIN open a trouble ticket. To obtain a ticket, click on https://widget.telus.tiia.ai/publicmobile/publicmobile.html and enter your question in SIMon. Follow / invent the prompts until you reach the Contact Us button, click on it and a Submit Ticket button should appear. To confirm that your ticket has been submitted, check the SEND box in your private messages; click on the small envelope next to your avatar at the top right of your screen.
If you have problems submitting a ticket, you can also send a private message to the moderators, but this alternative contact method may have a longer response time. Click: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
04-02-2021 03:12 PM
You would have chosen your 4 digit PIN when you first activated your account. If you don't remember, maybe check texts from Public mobile. You would have received a text from PM when you first activated your account.
