6 hours ago
I am having the same issue and YES I have another subscription plan in my Carr and have no clue how to get it out as I don't want it at all!! What can I do?
2 hours ago
if you get the error about you need to change or start a Subscription plan, that actually indicates the system was unable to link your current email login with a My Account. No worries, easy fix for PM support and you just need to engage them by direct message:
