09-14-2021 07:30 PM - edited 01-06-2022 03:31 AM
I need help logging into my account .... I cannot remember the email I used to set up my public mobile account! What do I do? Please help!!!!
My Account
09-15-2021 12:51 PM
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice Service Team they will help you 100%.
and they will Reset for you,
Here’s How To Contact Customer Support Agent by CS_Agent,
- you can send a private message to Customer Support Agent by CS_Agent, by Click Here link,
- You’ll need to be logged in to your Community account for the link to work.
- please include in your message,
- your account number,
- your phone number,
- your account 4 digit pin,
- your Email address,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
Good Luck....
09-14-2021 09:59 PM
@kidcowgirl wrote:I need help logging into my account .... I cannot remember the email I used to set up my public mobile account! What do I do? Please help!!!!
Is the account you are trying to access in Suspended status due to non-payment?
After 90 days of suspended/non-payment status, your account will be permanently deactivated, which means you will:
1-Lose access to your phone number (and Self Serve account), any rewards or Available Funds balance that was in your account at time of suspension, and won’t be able to transfer the phone number to a new provider in the future.
2-Need a new Public Mobile SIM card if you decide to activate a new Public Mobile account.
09-14-2021 07:33 PM - edited 09-14-2021 07:34 PM
@kidcowgirl if forgot password link does not work since you don't have the correct email address, you will have to open a ticket with PM
you can so by using the Chatbot on the lower right
type: Forgot log in information
Click "Contact Us"
Click "Click here to submit a ticket"
After ticket successfully opened, keep checking your Community inbox (envelope icon on top right) CS Agent will communicate with you there
09-14-2021 07:32 PM
Put public mobile in the search bar of the emails you do use to find the welcome email from public mobile.
