Re: Beginner’s Guide to the Community
charlesdnewman3
Hey i am just wondering why my internet doesnt work
445935293
Normally, it should works automatically. Sometimes you1 will need to set it up. Search data setting for instruction
HALIMACS
@charlesdnewman3
Presume you're referring to mobile data and not Wi-Fi.
Before troubleshooting, check under your data and add-ons in your self serve to make sure data is showing as remaining.
Then,  check/try the following:
  • Try Restarting Your Mobile Phone
  • Check If You're On Airplane Mode
  • Make sure mobile data is toggled on
  • Check If You're Using The Right Mobile Network
  • Re-Insert Your SIM Card
  • Reset Your APN
  • Change Your APN Protocol
  • Manually Enter Your APN
  • Ensure your phone has the latest updates
cellphoneuser1
Did you activate just now?  Did it work before?  If it didn't ever work, adjust your APN settings.https://www.publicmobile.ca/get-help/articles/set-up-data-on-an-android-phone
If it worked before, go into your account and look for the amount of data remaining. If nothing is shown, that means all data has been used.
