Question
wang55tong9
I want to solve the problem of transferring the public account, what should I do?
8 REPLIES 8
We have different views and different understanding of the question (with limited details provided).
We respect each other and  provide different fixes based on what we see.
OP comes back and picks the correct one.
In the end, OP is the ultimate winner (issue resolved).  Happy to see that  🙂
Moved:
Shall we take wagers on this one?
Yummy
Please provide more details regarding your problem.
Hi @wang55tong9  you want to transfer your account to another person? start with removing your credit card (needs CS agent help) or change email address (also needs CS agent help)
or you are porting out your number with problem?  No text from PM ?
Give us more details and we can try to help
or you can open ticket with CS agent (if you need to remove credit card, change email address, or ask why not porting text sent):
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@wang55tong9 or  Are you trying to put the public mobile account in someone else name to take over ?
dust2dust
Transferring which way? In to Public? Or away?
@wang55tong9
you are not receiving the text from your old provider? or you entered incorrect porting info?
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox.  Check the envelope icon on top right.  Call them and get it fixed
