07-30-2026 10:42 PM
Just curious if 8gb of data per month is enough. Generally I will likely only use it to send iMessages potentially check bank balances and maybe scroll the odd time or quickly search a question up on safari. What do you guys think?
Cole
07-30-2026 10:50 PM - edited 07-30-2026 10:51 PM
sounds like you and I use our data in similar fashion....I use wifi whenever possible. I have 3gb plan and only rarely get to use it all.
07-30-2026 10:45 PM
Honest, it really depends
But if you don't watch too much video or reels, use Wi-Fi as much as possible when you are outside, 8GB is more than enough.
