07-30-2026
10:50 PM
07-30-2026
10:53 PM
07-30-2026 10:54 PM
To "cancel" the plan, you can either port out your number to another provider and your account will be closed upon successful port out of the number
Or you can disable the toggle "Subscribed" to disable Pre-Authorized payment instead. Once it is disabled, PM will not be able to renew your account on your next renewal , your account will then be suspended on that day and 90 more days, it will be closed
To disable Pre-Authorized payments (Turn off Subscribed) , you can do it by one of the following:
Or if you cannot login My Account to disable Autopay,you can private message CS Agent and ask them to remove the credit card from the system:
07-30-2026
10:53 PM
07-30-2026
10:55 PM
port your number to new provider then your Public Mobile account is automatically closed You can also message Customer Support to request your payment card details be scrubbed...
