03-11-2024 08:10 AM
I use to be on the $34/40gb 5G unlimited after CAN only plan
recently renewed to the now-expired $34/50gb 5G CAN/US plan
Now my cell IP (regardless if 3G/LTE/5G) is Quebec based though some ip resolver sites says Timmins, ON, it actually is a Quebec IP
https://nordvpn.com/what-is-my-ip/
No matter reboot, turn off data for hours, even a new IP is Quebec based
how do I get back an ON IP?
anyone else notice this?
03-11-2024 10:25 AM
Why does the US/CAN plan force a Quebec IP?
In the 8 years with PM, my IP has always been Ontario, up to last week when I was still on a Canada only plan.
03-11-2024 08:27 AM
it is not something you can control. it is based on the system/tower you are connected to. For example, all the Eastern provinces are using the QC IP (mainly because the network servers are all in Quebec)
if you really need an Ontario IP for any reason, you might need to use VPN instead
